Bentley SACS 2025 - Release Highlights
Thảo luận trong 'SACS SOFTWARE' bắt đầu bởi BigCrab, 2/7/25 lúc 19:39.
  1. BigCrab
    Pile3D – Multiple Pile Analysis and Superelement Generation
    Pile3D now supports multiple pile analyses using 3D Finite Element Analysis of the pile/soil interaction for improved performance and convergence over PSI analyses. Simply select a Pile3D input file in the Analysis Generator for the PSI/Pile input file when creating your analysis. Pile3D integrated multiple pile analysis now also supports pile linearization for seamless integration into SACS dynamic analyses with Wave Response or Dynamic Response simulations. Full details of these enhancements may be found in the PSI/Pile documentation.
    Post - AISC 360 (2022) Design Code Check
    AISC Steel Construction Manual 16th (AISC 360 2022) has been added to SACS Post design code checks. AISC 16th may be used with API RP 2A 21st and 22nd editions with both WSD and LRFD methods. This update included changes to Hollow Structural, Channel, Box, Wide Flange, and Plate Girder sections. Full details of the changes may be found in the Post documentation.
    Joint Mesher – Conical Section Meshing
    A new method has been added to Joint Mesher enabling conical section meshing. The Simplex Mesher creates a set of surfaces of 1D beam elements and computes the intersections of these surfaces using numeric algorithms instead of analytical formulae. This methodology allows for more complex types of connections that previously were unsupported by Joint Mesher. Conical sections are now supported using the new Simplex Mesher methodology. The Legacy workflow is still supported as the default method for mesh generation. More details about this enhancement may be found in the Utilities documentation.
    ADINA Interoperability – Non-linear Dynamic Model Export
    Export SACS models with dynamic mass properties and dynamic force time series with the SACS-ADINA Interop utility. ADINA is Bentley’s general non-linear dynamic finite element analysis software for advanced analyses and enables advanced non-linear dynamic analyses of offshore structures. Previously this feature was limited to non-linear static export of SACS model data with some model conversion options. This update adds the ability to export dynamic mass properties of a Dynpac Input file and base driven accelerations or force time series from a Dynamic Response input file.
    Export of the linear static model data is still accessible as a command through Precede, but export of the non-linear dynamic model requires an additional SACS ADINA Interop Input File and a SACS ADINA Interop Analysis run file accessible in the Analysis Generator under the Utilities analysis type. More information about the SACS ADINA Interop utility can be found in the Utilities manual.
    [​IMG][​IMG]
    SACS Cloud Services (Early Access Program)
    Perform massively parallelized wind turbine analyses with SACS Cloud Services. The Bentley Cloud Services platform has been completely updated with improved performance, reliability, and reporting. This early access program enables anyone performing SACS Wind Turbine analyses (Uncoupled Strength, Uncoupled Fatigue, and Dynamic Superelement) to perform hundreds of analyses simultaneously in the cloud for significant performance gains when compared with traditional desktop hardware. This service has now been extended to all users.
    SACS Wind Turbine Naming
    OpenWindPower – Fixed Foundation has been renamed to SACS Wind Turbine. SACS Wind Turbine is functionally the same as OpenWindPower – Fixed Foundation; there are no changes to the license apart from the name change itself.
